Delivering to Different Postcodes
marcob
Member
I am struggling to set up delivery options for my products which are delivered on pallets. Different products are sized differently this means that we have different quantities for each product/pallet.
Our current quantities per pallet are 225 pcs, 120 pcs and 90 pcs.
We delivery throughout the UK and the transport firm that we use has a tiered pricing structure based on the which postcode they are delivering to.
This is split into 6 zones, each with a spread of postcodes in each zone and a different pricing structure for each zone.
Typically we will deliver up to 4 pallets using this method.
Any ideas would be gratefully received as this is now driving me insane.
Marcus
3 REPLIES 3
Tracey
Guru
Hi marcob,
If you can please supply your domain name we would be able to assist further.
Tracey
BT Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
marcob
Member
Hi Tracey,
It's welaway.co.uk.
Marcus
Tracey
Guru
Hi Marcob,
If you email the team on [email protected] they will be able to assist you with this without an problem.
Hope this helps
Tracey
BT Forum Moderator
