Help Interleaving
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi ok,
For the past 10 years with several providers i have acheived between 10-15ms with Fast path, I started my service on the 3rd Febuary and was acheiving 12ms last hop to bbc.co.uk. A trace from my previous provider,
1 <1 ms <1 ms <1 ms 192.168.0.1
2 10 ms 10 ms 10 ms 188.39.0.30
3 9 ms 10 ms 10 ms gi1-8.the.dist.dsl.enta.net [188.39.0.29]
4 10 ms 10 ms 10 ms te2-2.telehouse-east3.dsl.enta.net [78.33.141.81
5 24 ms 10 ms 10 ms te5-2.telehouse-east.core.enta.net [62.249.192.1
21]
6 10 ms 10 ms 10 ms te5-1.telehouse-east2.core.enta.net [87.127.236.
98]
7 9 ms 10 ms 10 ms 212.58.238.177
8 10 ms 10 ms 9 ms 212.58.238.153
9 10 ms 10 ms 10 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
A few days later the interleaving got kicked on and i was told to wait 10 days for the training period to stop to remove it, So i waited and on the 14th i then asked for it to be removed... And eventually they told me they sent an order to get it removed.
48 hours later i am still seeing the increased ping from the interleaving and have been told it has been removed from my line, Below are stats showing that interleaving is still on.
Status: ShowtimeRetrain Reason: 8000
Channel: INTR, Upstream rate = 960 Kbps, Downstream rate = 7296 Kbps
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.6 7.0
Attn(dB): 43.0 26.5
Pwr(dBm): 19.8 12.7
Max(Kbps): 7872 1136
Rate (Kbps): 7296 960
G.dmt framing
K: 229(0) 31
R: 16 8
S: 1 4
😧 32 4
ADSL2 framing
MSGc: 59 10
B: 120 46
M: 1 4
T: 2 3
R: 10 4
S: 0.4962 5.9076
L: 2112 260
😧 64 4
Counters
SF: 4837 4777
SFErr: 0 0
RS: 328946 81209
RSCorr: 80 0
RSUnCorr: 0 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1415545 0
Data Cells: 542 0
Drop Cells: 0
Bit Errors: 0 0
ES: 3 0
SES: 0 0
UAS: 96 0
AS: 83
INP: 1.21 0.24
PER: 16.12 17.72
delay: 7.93 5.90
OR: 32.24 7.22
Bitswap: 0 0
Strange enough i thought id try adsl2+ mode out to test so i did...
Channel: FAST, Upstream rate = 1011 Kbps, Downstream rate = 7770 Kbps
Mode: ADSL2+
Channel: Fast
Trellis: U:ON /D:ON
I am currently connected with adsl2+ and i am seeing,
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
2 19 ms 19 ms 19 ms 217.32.141.34
3 21 ms 21 ms 22 ms 217.32.141.62
4 22 ms 22 ms 21 ms 213.120.161.50
5 22 ms 22 ms 22 ms 217.41.222.50
6 22 ms 21 ms 22 ms 217.41.222.182
7 22 ms 22 ms 21 ms acc2-10GigE-0-0-0-4.bm.21cn-ipp.bt.net [109.159.
248.194]
8 28 ms 28 ms 27 ms core1-te-0-2-5-0.ilford.ukcore.bt.net [109.159.2
48.128]
9 27 ms 27 ms 27 ms core1-pos9-1.telehouse.ukcore.bt.net [194.74.65.
114]
10 228 ms 223 ms 219 ms 194.74.65.42
11 27 ms 28 ms 27 ms 212.58.238.153
12 28 ms 27 ms 27 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
The trace from g.dmt currently shows,
2 13 ms 13 ms 12 ms 217.32.141.34
3 14 ms 13 ms 14 ms 217.32.141.62
4 15 ms 15 ms 15 ms 213.120.161.50
5 15 ms 15 ms 15 ms 217.41.222.46
6 16 ms 15 ms 15 ms 217.41.222.182
7 16 ms 15 ms 16 ms acc2-10GigE-0-7-0-4.bm.21cn-ipp.bt.net [109.159.
248.198]
8 21 ms 20 ms 20 ms core1-te-0-13-0-4.ilford.ukcore.bt.net [109.159.
248.136]
9 21 ms 21 ms 20 ms core1-pos9-0.telehouse.ukcore.bt.net [62.6.201.1
18]
10 21 ms 21 ms 21 ms 194.74.65.42
11 20 ms 21 ms 21 ms 212.58.238.129
12 20 ms 20 ms 20 ms virtual-vip.thdo.bbc.co.uk [212.58.224.138]
When i first started the service these pings were -10ms as what they are now, Im running around in circles what am i supposed to do, My end still showing interleaving but they say its off and are now blaming me?
More stats from the modem,
System Status System Uptime: 23:5:24
Primary Secondary
LAN Status Primary DNS: 195.74.113.58 Secondary DNS: 195.74.113.62
IP Address TX Packets RX Packets
192.168.2.1 1138827 1145082
WAN 1 Status
Enable Line Name Mode Up Time
Yes SDSLADSLEthernet PPPoA 00:00:00
IP GW IP TX Packets TX Rate(Bps) RX Packets RX Rate(Bps)
--- --- 0 0 0 0
Message [ PPP Shutdown ]
WAN 2 Status
Yes Ethernet --- 00:00:00
--- --- 0 0 0 0
SDSLADSL Information ( SDSLADSL Firmware Version: 332201_A)
ATM Statistics TX Cells RX Cells TX CRC errs RX CRC errs
246594 33206010 203 150
SDSLADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
G.DMT SHOWTIME 1152000 6912000 6 42
Am i right in thinking if it was off then i wont see the errors above? Since interleaving is error correcting and if it was indeed off then these would show as 0 as they did with my last provider...
System Status System Uptime: 498:11:2
Primary Secondary
LAN Status Primary DNS: 194.74.65.69 Secondary DNS: 74.82.42.42
192.168.2.1 16478663 11423677
WAN 1 Status
--- --- 0 0 0 0
WAN 2 Status
--- --- 0 0 0 0
9521188 301313422 0 0
G.DMT SHOWTIME 896000 6304000 8 44
Sorry for the long post but im getting really frustrated trying to resolve this and im not getting anywhere, I appreciate your replies and any advice given.
Regards
Darryl Williams
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
All indications when testing did actually appear to show that interleaving was disabled. I'm having them ensure that it's disabled across the system... again this is potentially this afternoon.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You know when you reconnect the internet, Like i said previously the ping sometimes is 5ms higher or lower, Would it not be possible to connect to a certain one that provides the best instead of it being random?
Also does the Home BT broadband provide better pings than the Business? Ive been told that its LLU and the Business isnt?
Cheers
Darryl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm guessing you're referring to IP. An IP is an IP, there's no fast or slow ones... they all do the same job. You also have to remember that response time to servers is also down to the servers themselves, the route to them can also change, and so could their response time... you're only as fast as your slowest hop. I can only assume this is online gaming related?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
For example when i trace bbc.co.uk sometimes the end hop will be 20 other times it was 25 and when it was 20 throughout the trace was also 5 lower so i was on a faster route would it not be possible to always have the same route?
Also about the Home question what about that? My mate who lives local gets 3-4 lower on it so i guess that would apply to me as well?
Cheers
Darryl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's all completely ISP dependant, I couldn't comment on the residential side. But 3 to 4ms is practically unnoticeable, especially with regards to online gaming. With a traceroute, we only take you so far before you're set loose and it's up to the net/DNS, servers etc to get you to the right place. It's all a case of load balancing etc, there's no way we can set a connection to take the exact same route every time as we simply don't have the power to do so. Again I'm just assuming this is online gaming related, if it is, is it PC gaming or console?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes online and for the PC ive had 10 before with other providers so i know it is possible to get it, Can you not do anything else to get it lower, Or can i do anything?
Cheers
Darryl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Beyond ensuring interleaving is disabled, there isn't really much that can be done by either of us. I've had similar issues with increased ping in the likes of Quake Live, that was due to the game going from beta to full release, and the increased player count via the master server was pushing it up slightly. They had moved to larger servers which meant slightly more overheads, wasn't really anything any of us could do.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok its finally turned off, But as i trace the server that i go in look below.
2 5 ms 5 ms 4 ms 217.32.141.34
3 6 ms 6 ms 6 ms 217.32.141.62
4 8 ms 8 ms 7 ms 213.120.161.50
5 7 ms 7 ms 7 ms 217.41.222.62
6 7 ms 8 ms 8 ms 217.41.222.182
7 7 ms 7 ms 8 ms acc2-10GigE-0-1-0-5.bm.21cn-ipp.bt.net [109.159.
248.218]
8 11 ms 11 ms 11 ms core2-te-0-13-0-4.ealing.ukcore.bt.net [109.159.
248.138]
9 23 ms 12 ms 12 ms core1-xe10-1-0.redbus.ukcore.bt.net [62.6.200.89
10 13 ms 13 ms 13 ms te8-4.core1.thn.as20860.net [195.66.224.207]
11 14 ms 22 ms 14 ms 62-233-127-174.as20860.net [62.233.127.174]
12 14 ms 14 ms 14 ms service8697.lrc-networks.co.uk [78.129.197.65]
Usually on my old provider it doesnt jump up so much like this, Ive also noticed that they start very low where my friend local to me has the same number throughout where mine starts low and slowly rises.
I usually start with 10 and end with it like he does, So i guess if i went to the home broadband i would be the same since they use different systems? Would it be possible for you to find out for me mate?
Cheers
Darryl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My old provider produced these pings morning to night didnt matter, Still used a BT line wasnt llu or anything.
21]
98]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Your old provider was using the Entanet network that will have fewer users than the BT wholesale network. I know you think that 4ms is 'a jump', but it certainly isn't even remotely high and would be considered a premium connection to game servers (living in Scotland, 14-20ms would be heaven :P). I believe most Entanet based ISP's have fastpath in place to give the shortest route to a server, I don't believe residential supply this so you may see comparative results as to what you're seeing here... there's just no way to guarantee that it would be better.
