Home hub v.15 vpn
Joncvs
Member
Hi
Hoping someone can help me out with this!
We have a Juniper SA700, clients login with windows 7 network connect vpn client.
I have problem with one user connecting from home via his bt home hub v1.5
His laptop works on another adsl line without a home hub, he's tried at his neighbours house who also has a home hub, same problem.
He can log into the vpn client ok, gets an ip.
When he tries to navigate to a mapped network drive e.g \\servername\storage it can't find it. If I type \\servername in the address bar I can only see the offline folders, so it doesn't appear to be connecting.
I've messed around with stupid home hub, using some instructions http://www.filesaveas.com/bthomehub_security.html
Turned off the firewall, although it not sure that would fix it as you still seem to have to setup a game or application through it. Tried setting up an application/port forwarding but not sure if I've got it quite right.
Any ideas would be most welcome!! Ironically I've just setup a draytek to do all sort of things, but a home hub and I'm stumped.
I do have two spare businesss hubs from our fibre install, if they give me any more options or an easier setup.
Jon
1 REPLY 1
Joncvs
Member
Just found something about web addressing help. Will try that first
