How to setup sub domain
JamesG
Member
Hi All I would be really grateful for any help. I want to set up a Wordpress site. I've got a domain and was given some advice that ideally I should set up a sub domain as a test server. I have the standard package and tomorrow will purchase the professional package. In the meantime could anyone tell me how to create a sub domain in simple terms. I've been through lots and lots of pages of help based on using cPanel but BT doesn't have cPanel and the posts I have found on this forum are too complicated. If my domain name is www.realsite.co.uk how do I create a sub domain called dev.realsite.co.uk? Many thanks in advance.
5 REPLIES 5
mikewash
Member
This should be a pretty straigh forward process. However, I'm not seeing any tutiorials here. I would suggest to call the tech support on this.
mydearcosmo
Power User
That would actually depend on your hosting plan. If the plan you subscribed is supporting sub domains, there is always a guide on how to do so.
Stephenc
Master User
Hi James,
This can be done quite easily, if you login to your account on http://myoffice.bt.com click - manage services - manage your domain name (under domains) - click on manage next to realsite.co.uk - click advanced domain manager.
On this page, there should be three fields, in a blank row in the box on the left type "dev" in the drop down select "A record" in the value box type, "209.235.144.9"
This should allow you to use this URL with your BT hosting.
Ian1974
Moderator
Moderator
Sorry,
However this is not actually possible with BT Hosting.
The only way to create a sub domain is to use Url or Frame forwarding to the relevant folder within your BT webspace or to another web server using an A record.
Kind Regards,
Ian -F-
BT Business Domains
seeman
Member
I think it's a very easy way to create a memorable Web address for unique content areas of your site.
