ISDN2e Line Problems
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
We connect to our sites via ISDN2e and there are 2 sites within close proximity to each other that I am having trouble with gaining a solid connection. I have had the devices on the end of the ISDN tested by our 3rd party and they have no problems connecting albeit they are in Bolton and we are just north of Newcastle upon Tyne. The ISDNs are in service as the sites can perform card authorisations and etopup transactions that go out through the ISDN.
I have reported the lines and our ISDN and nothing out of the ordinary has been found. It seems I can only get a stable connection during certain times of the day although I am yet to prove this. There is nothing wrong with our equipment at our end because if there was we'd have problems connecting to more than these 2 sites. I'd like to avoid the charges for their 3rd line investigation and also wasting an engineers time going to site and finding nothing wrong. What can I do to prove that there is a problem of some sort and who can I prove this to? I had the same problem 2 years ago, nothing was done and it disappeared then, 2 years later it is back and I cannot resolve it.
Any advice will be gratefully taken on board.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello shillr,
It seems, from the information provided, that the ISDN2e lines are working correctly, as:
shillr wrote:We connect to our sites via ISDN2e and there are 2 sites within close proximity to each other that I am having trouble with gaining a solid connection. I have had the devices on the end of the ISDN tested by our 3rd party and they have no problems connecting albeit they are in Bolton and we are just north of Newcastle upon Tyne. The ISDNs are in service as the sites can perform card authorisations and etopup transactions that go out through the ISDN.
Did the 3rd Party test the "the devices" in situ, via the "problem" ISDN2e lines, or by taking them to their Bolton offices, and testing them there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Our 3rd party tested the devices in situ via ISDN from their site in Bolton and received no connection loss.
To answer your questions hopefully correctly as I am unfamiliar with the CPE term....
1, The device at the other end of ISDN at the problem sites are Sarian IR2140 ISDN routers. We run the same devices at all of our sites, apart from the centre where a Cisco 1600 Series router is used.
2, The testing that was conducted was a simple ping test. The software on the router can be accessed via a web browser and is the same across all of our sites, no versioning difference. To my knowledge there has been no need for any firmware upgrades and the software at the centre has been fine. Our 3rd party has dial in access to our router and was able to perform the same test I did getting an inconsistent connection.
We only get this problem if we are trying to pull information from the sites, we can send information to the sites without issue. I don't know if this helps but its the common denominator with the 2 sites in question.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
