LOGIN TO EMAIL?
muggy333
Member
Having now spent the last 2 weeks filtering spam on this new wonderful 365 I have come home tonight to find I can no longer login in to my email account, I have had to also open a new account to post on this forum as it no longer recognizes my password. This brilliant! Any ideas? (SICK OF THIS)
5 REPLIES 5
suntattood
Power User
If you want help, you can elaborate your issue more so everyone could understand completely.
muggy333
Member
When I login in to email account it will not accept my password, if I try to reset password it will not accept the answerer to my security question, also I cannot access this forum with my original login details I have had to re register. Hope this might help.
lauderfox
Member
I'm in a similar situation - suspect email has been hacked and original password changed. When I try to reset it does not accept my answer to the security question, which I know is correct! Any moderator with a solution?
JillCurtis
Member
settings for btconnect email on a Imac
Burkem5
Guru
For any issues where you suspect that you have been hacked or that your account has been compromised I would highly recommend that you contact us
