Hi,
I have been trying to get multimap embedded on my website but to do this i need to use a html code which I know nothing about. Can someone please advise me on how to do this.
Cheers Pete.
Solved! Go to Solution.
If you are using EasySiteWizard Pro, it can't be done. Instead, you can use the Google Maps tool that is provided with it.
If you are using EasySiteWizard 6, click on View > HTML source and you can edit the HTML that way.
Hi Pete,
You need to signup for the API here:
http://www.multimap.com/openapi/
This should take you through to generate the code you need.
Thanks for the reply, I know how to get the html code to get the map embeded I just don't know how to put the code into my website as I don't know how to use html. I use Easy Site Wizard so have never used html. Any suggestions?
Cheers Pete.
cheers for that I was using the easy site wizard 6 so just pasted the html on to the end of the existing html and the map has appeared.
nice one, Pete.
