Multiple Static IP
p4rma
Member
Hi,
I have purchased a set of 5 usuable static ip's. The router is configured and the static ip has been assigned to the selected PC. However, the setup I would like to achieve is as follows; All of the devices should have an internal ip address 192.168.1.x and so on. Then for the firewall to use one on one nat to map the external ip to the internal one?
I am using the business business hub as provided with BT Infinity.
I hope someone can help!
1 REPLY 1
a-hill
Grand Master
Hi p4rma,
Unfortunately the Fibre Hub doesn't support 1:1 IP mapping so you won't be able to achieve your desired setup using that router.
