I have just moved my broadband connection and everything to BT, everything is working fine except the two domains I transferred across, emails are fine I can send and recieve but my webspace isn't, according to my product details I have this...
Business Essentials (1)
Everything you need to get started with your new broadband connection.
Includes:
A dedicated business portal & access to a dedicated homepage.
10 Business email Lite accounts ([email protected])
[email protected] email and web access
50Mb space per mailbox
20Mb web space
24 hour helpdesk (local rate number - with broadband)
But I cannot see how I access my webspace to up load my websites, the only option I see says that it cannot be used with domains which seems a bit pointless.
Solved! Go to Solution.
Hi
It sounds like you do not have BT Business WebHosting package. If you would like BT Business to host the actual pages you would need a webhosting package which starts at £5 a month.
If you private mail me your account details or domain details i can check what package you have, and supply more information on what services you have.
Kind Regards
Fiona
BT Business Forum Moderator
Hi
Kind Regards
Fiona
Hi, thanks for the reply, I must confess that I did suspect that it maybe the case. I warn all my customers that BT look cheap on paper but once you start adding up the extras they become costly as a provider.
Ah well, I have setup web forwarding now and will look at getting the customer back away from BT asap.
Thanks again.
