Nexus 7
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, I have just bought myself a new Nexus 7 tablet. I am having difficulty setting up the correct e-mail settings. They seem to be accepted but then I do not receive and can not send mail. Please can you advise. Thank you.
For incoming settings I have put my user name and password.
pop3 server: pop3.btconnect.com
security: none
Port 110
Outgoing settings:
SPTP server: mail.btconnect.com
Security: none
Port 587
Left sign in box empty.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
If you're not migrated and still using the btconnect.com servers, then you need to use port 25, not 587.
Dave
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for your reply. I changed the port to 25 as you said. Each time I press done it reverts to 587.
Julia
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Julia,
That is quite odd, is ssl turned on? It generally has a tendancy to change port numbers.
Although I do notice you have said security off.
Also if you are not on a bt connection, i.e. the 3G network, you will need outgoing authentication set to password.
Thanks,
Steve
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Steve, I do not have any security settings.
When I tick the box require sign in, and put my e-mail address for my username and usual password I get 'couldn't open connection to server'. The port is still reverting to 587. I have tried the smtp server as mail.btconnect .com as well as smtp.btconnect.com.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I also get a different response sometimes:
Username or password incorrect. [535.5.7.3 Authentication unsuccessful}
However I am using the same details I always use.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I found it works if you leave the sign in box empty and change port to 25 for outgoing settings.
See below
Outgoing settings:
SPTP server: smtp.btconnect.com
Security: none
Port 25
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your suggestion Julian.
Those are exactly the same settings that I am using but when I put 25 for the port setting, it reverts to 587 automatically when i press 'done'.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My nexus 7 keeps going back to 587 too. Seems impossible to get 365 to work.
Anyone?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
