Not good after ADSL2+ upgrade
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
hi
Anyone else not having a good experience after upgrading from ADSL2 to ADSL2+ (CN21)
Even though our router is ADSL2+ compatible and modulation set to the correct setting, got many ADSL drop offs, sometimes (10 drops in 15mins, sometimes fine for a couple of hours)
Had to go back to the G.DMT modulation for some slow stability.
Our BB was only 3mb anyway.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
great im getting answers from Draytec to try other ADSL firmware codes namely
E.67.02.52 & .55
Its unbelivable, its a lottery as to what ADSL firmware will work best!
So there are many manufacturers and many ISPs, that makes alot of combinations
Surely ADSL2+ is ADSL2+ or were all doomed!
So BT, what 'settings' are you using for my ADSL2+ so i can choose the correct ADSL firmware to match your ADSL2+
Or do you want me to keep trying other firmwares to see if one happens to match?
Wouldnt be so bad if testing took 10 mins, but last firmware i tried to 3 days to totally bomb out, on a Sunday night, which required an office visit by me to swap routers to the old settings.
Im getting a little annoyed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Simon,
I chased this up earlier and am currently awaiting a reply, I will update when I have a response.
Alun
BT Business Support Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks Alun, pressing F5 every hour
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
another day gone, we are a business, and not a 2 man band (not that they arent just as important)
This should be answered same day, not a week later.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Alun? Any news? Ive received nothing, is there a phone number other than bog standard tech supp.
I think we have been patient
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
The vigor 2800 does seem to have some bad press related to it's ADSL2+ functionality.
Try here for the 3.3.4 firmware which you don't seem to have tried yet I don't think?
** on further reading this version has it's own problems, might be worth a try but I'm still reading a bit about it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Simon,
Just got a reply to say that the issue is getting looked at right now.
Alun
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
The 2800 seems to have an issue with INP (Impulse Noise Protection) or Interleaving which has 5 settings, off and INP1, 2, 4, and 8. There are a few posts were it's suggested the 2800 doesn't support INP2...whether you are on that by default I don't know but I'm trying to find out how to check. But the problems with this seem to match yours.
So you could call BT tech and request that interleaving is turned off, a fault would need to be raised to wholesale to get this done for you but tech do definately do it.
You could also try the new 3.3.4 firmware and change the modulation setting to Annex M, some users have reported better performance and stability with this setting, even although the ISP doesn't support it.
Here is a link to the supported firmware for ADSL2+ in the UK, its V2.8.2...I think you mentioned it earlier though.
Heres a link to some interesting forum posts on drayteks site (you have to sign up but its worth it)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Appreciate the replies.
I see no 3.3.5 firmware, nothing new from when i started looking 2 months ago
Im not looking for better performance, im looking for a signal that stays ON, that doesnt drop 20 times a day.
I havent even got to the performance yet.
Clearly ADSL2+ upgrade was too early. Its not been tested enough.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
it's 3.3.4 and I was talking about the dropping connection...the reason it's dropping is because the router can't handle the higher frequency that ADSL2 runs on and is also incompatable with the type of interleaving that 'could' be on your line, the forum posts I linked should back that up. Turning interleaving off may improve it...it's worth a try.
