Our village hall needs a phone line
KatieW
Member
There is no phone line at present - the hall was built only 30 years ago, but that is long before phone & broadband connection was essential. How do we get quotes?
3 REPLIES 3
markp
Grand Guru
Hi KaiteW,
I have sent you a private message, if you can respond to this I can get you in contact with the correct team.
Markp
villager101
Member
Hello
Our village hall is also thinking of installing broadband (we have fibre optic in the village) but we don't have a phone line.  Can you please let us know what is our best option.
Thank you.
markp
Grand Guru
Hi villager101,
unless your are going for something line a leased line/private circuit, you would need to have a telephony line first, as standard ADSL/fibre broadband piggybacks on the telephone line.
If the hall as no line at the moment you will be able to order a new line with broadband.
I will send you a private message, if you can reply to this I will be able to get someone to call you to explain your options.
Markp
