Pics and hyperlinks
PTWA
Member
Hi,
I'm new to EasySite builder...
Is is possible to embed a hyperlink on a graphic?
Ta muchly
Sal
1 ACCEPTED SOLUTION
Accepted Solutions
dave
Guru
Yes it is possible.
Double click the picture, select the "i" symbol underneath (image properties) and put the URL to be hyperlinked to in the URL field.
View solution in original post
5 REPLIES 5
TheOtherOne
Super User
Hi Sal,
Which EasySiteWizard are you using??
Regards,
TheOtherOne 🙂
"He was standing, gazing northwards into the darkness, thoughtful and silent as a young tree in a windless night"
PTWA
Member
easySite Wizard Pro
Any help gratefully received - it looksreally crappy otherwise!
dave
Guru
Yes it is possible.
ace123
Member
I am trying to hyperlink an image from kitco.com , which is a live update graph. onto home page I have tried many many times, including putting the url or pasting the html code, BUT never comes live when publishe. ditto for a webcounter image.
- any ideas please
BLWRAVE
BT Partner
BT Partner
Hello
When you go to "image properties" and save the changes and then go to editing page before you publish is your picture there? When you publish does it come up on the live site?
