Problems installing phpMyAdmin
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello. I'm trying to install phpMyAdmin on the server, using BT's browser installer. However, after I enter my desired username and password (at the final stage of the install) it tells me the installation has failed, but gives no explanation as to why. I desperately need to edit a MySQL database - any solution to this would be greatly appreciated.
Thanks!
Mystic G
0
Kudos
2 REPLIES 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I would contact BT about this as it sounds like a configuration issue.
In the meantime, if you are desperately needing to access the database, and since BT allow external connections to their database server, you could use something like Navicat Lite or HeidiSQL which would do a similar job but run on your local machine.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks Dave i will give this a go.
0
Kudos
