Good morning all,
I have had a little dig around google and these forums.
It seems that the Engineer can move the Master Phone socket over to any other existing phone socket in the house?
Is this correct?
Right now where the Master phone socket is located is not the most ideal place to have the new infinity modem connected.
If it could be moved to another Phone socket it would be most useful.
Can someone confirm that this can be done and that the Engineer can do it on install day?
Regards,
Josh
Solved! Go to Solution.
Hey Josh4321, I was just looking on google myself since i'll hopefully be getting infinity soon.
If you read this (click me!) you should find what you're looking for.
