Hello,
I tried it and got this,
Sorry, you do not have sufficient privileges for that action.
Please click the Back button on your browser.
How do I get sufficient privilages?
Thanks for any help.
Mike
Hi
Did you manage to get this resolved?
Kind Regards
Fiona
BT Business Forum Moderator
Hello Fiona
I have just tried again and got the same response.![]()
Kind regards
Mike
Hi
I'm really sorry it still isn't working, can you please supply the domain name and i can ask someone to have a look at it.
Kind Regards
Fiona
Hello,
Is it the Easy Site Wizard or the Easy Site Wizard Pro that you are using? In my experience I have seen that even using incorrect casing when loggin in to your control panel will cause issues with Easy Site Wizard. If you aren't already doing so try to to ensure that you use all lowercase letters when signing in to your BT Hosting control panel.
Cheers
