Can someone please help? Domain redirect again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Ok. tinyponyrugcompany.co.uk is my primary domain name but I need to point littlewelshrugcompany.co.uk at it too.
However, when I try to do so there's already a www record set up for the littlewelshrugcompany.co.uk so I can't change it!
I've used BT for websites etc many a time before and not encountered this particular problem.
Any help greatly appreciated
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
When you set up additional domain names you are not provided with root-level access, however, you should be able to redirect your domain name to another URL without having to change the www record. It sounds like you are trying to set up Frame Forwarding rather than URL Forwarding.
If you need to set up Frame Forwarding or alter any of the Zone Settings you will need to contact the Technical Helpdesk to go through the changes, this is to ensure there are no errors with the forwarding.
Kind Regards
Fiona
BT Business Forum moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Fiona
No, it doesnt work with URL forwarding either, I tried that first as this is the way I had always done this before.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I'm really sorry that this isn't working, you would need to report this to the Technical team, they can check the Zone setting on the account and set it up for you. It sounds like it must be an issue with the Domain Centre.
Kind Regards
Fiona
BT Business Forum Moderator
