I was told to leave my router connected for 72 hours and DLM would change my SNR to 6dB but it jasn't changed. I haven't been disconnected recently and my connection can handle 3dB. It only increased because of a storm a while back.
Here are my stats:
adsl: ADSL driver and PHY status Status: Showtime Retrain Reason: 0 Max: Upstream rate = 17178 Kbps, Downstream rate = 17488 Kbps Path: 0, Upstream rate = 968 Kbps, Downstream rate = 14355 Kbps Link Power State: L0 Mode: ADSL2+ TPS-TC: ATM Mode Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 9.2 5.5 Attn(dB): 26.0 13.7 Pwr(dBm): 21.1 12.1 ADSL2 framing MSGc: 51 14 B: 254 121 M: 1 1 T: 2 1 R: 0 0 S: 0.5672 4.0000 L: 3596 244 D: 1 1 Counters SF: 17966320 263324 SFErr: 2178 16141 RS: 0 0 RSCorr: 0 0 RSUnCorr: 0 0 HEC: 1666 10983 OCD: 134 0 LCD: 0 0 Total Cells: 1245024651 663152135 Data Cells: 611448427 86446980 Drop Cells: 2380682 Bit Errors: 0 984067 ES: 1616 15430 SES: 8 0 UAS: 18 18 AS: 290479 INP: 0.00 0.00 PER: 16.16 20.00 delay: 0.14 1.00 OR: 28.20 8.00 Bitswap: 11304 6334 Since Link time = 3 days 8 hours 41 min 19 sec FEC: 0 0 CRC: 2178 16141 ES: 1616 15430 SES: 8 0 UAS: 0 0 LOS: 0 0 LOF: 0 0
Is it possible that my SNR is stuck?
Hello dmk001,
Generally speaking a SNR of around 6db is ideal for the broadband to work, though depending on line length and equipment on the connection (routers, PSTN items etc...) a SNR variation of 3db either way is OK for the broadband to work.
You mentioned that a storm has came your way a while back - since then has the connection got a lot worse? Do you experience slow speeds or drop outs?
When it comes to routers / modems being on the connection at hand, we generally advise customers to keep them connected, switched on - as if the exchange picks up it going off every day - it can detect wither it is dropping due to a fault or wither it is being switched off every night- that is no doubt you where advised to leave it connected for 72 hours.
Have you tried changing your ADSL Microfilter? Do you have extensions? The telephone point that the modem / router is connected to - does it have a removable bottom half that you can take off by remove the screws? If so, on the bottom right hand side, there is a test socket - try plugging the filter into that and monitor.
These are some basic things you can try yourself to see if the connection improves, stay's the same or gets worse.
If it does not get better, you can always Contact Us
Another thing as well in between 8pm - 12am Xbox is impossible to play because I get huge amounts of packet loss. I would of though that business connections would of had priority however this seems not to be the case. I've had so many problems with BT I'm thinking about leaving going to a more reliable provider. This problem is very recent, it started happening 3 days ago and has been continuous since then. Latency has also increased from 12ms to 16ms sometimes jumping to 21ms somedays, the problem has only occured when the latency increased.
I've provided some traceroutes from my connection and to my connection:
Tracing route to bbc.co.uk [212.58.251.195] over a maximum of 30 hops: 1 1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254] 2 17 ms 18 ms 16 ms host81-148-0-1.in-addr.btopenworld.com [81.148.0 .1] 3 17 ms 16 ms 16 ms 213.120.178.141 4 18 ms 18 ms 18 ms 213.120.177.98 5 18 ms 17 ms 17 ms 217.41.168.177 6 17 ms 18 ms 17 ms 217.41.168.107 7 17 ms 17 ms 17 ms 109.159.249.68 8 23 ms 23 ms 23 ms core1-te0-15-0-4.faraday.ukcore.bt.net [109.159. 249.29] 9 17 ms 18 ms 18 ms peer2-xe8-0-0.telehouse.ukcore.bt.net [109.159.2 54.177] 10 18 ms 17 ms 18 ms 194.74.65.42 11 * * * Request timed out. 12 * * * Request timed out. 13 18 ms 19 ms 17 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109] 14 18 ms 18 ms 18 ms 132.185.255.140 15 19 ms 19 ms 19 ms www-vip.telhc.bbc.co.uk [212.58.251.195]
1 2ms RS-Gateway.local [78.129.174.1] 2 0ms 87.117.211.45 3 1ms 593.core1.thn.as20860.net [62.233.127.173] 4 1ms linx1.ukcore.bt.net [195.66.224.10] 5 9ms core1-te0-8-0-2.faraday.ukcore.bt.net [109.159.254.180] 6 1ms acc2-10GigE-0-4-0-0.l-far.21cn-ipp.bt.net [109.159.249.128] 7 2ms 109.159.249.226 8 2ms 217.41.168.108 9 2ms 217.41.168.190 10 1ms 213.120.177.101 11 2ms 213.120.178.145 12 * Request timed out. 13 17ms host81-xxx-xxx-xxx.in-addr.btopenworld.com [81.xxx.xxx.xxx]
Both traceroutes show an increase in latency at Faraday
Usually when the connection is normal:
Tracing route to bbc.co.uk [212.58.253.67] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254] 2 14 ms 13 ms 13 ms host81-139-128-1.in-addr.btopenworld.com [81.139 .128.1] 3 13 ms 13 ms 13 ms 213.120.178.141 4 14 ms 14 ms 14 ms 213.120.177.98 5 15 ms 13 ms 13 ms 217.41.168.177 6 14 ms 14 ms 14 ms 217.41.168.107 7 14 ms 14 ms 14 ms 109.159.249.110 8 14 ms 14 ms 14 ms core2-te0-7-0-16.faraday.ukcore.bt.net [109.159. 249.9] 9 15 ms 15 ms 14 ms peer2-xe8-3-1.telehouse.ukcore.bt.net [213.121.1 93.111] 10 14 ms 14 ms 14 ms 194.74.65.42 11 * * * Request timed out. 12 15 ms 14 ms 15 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93] 13 15 ms 16 ms 16 ms 132.185.255.156 14 15 ms 16 ms 15 ms www-vip.cwwtf.bbc.co.uk [212.58.253.67] Trace complete.
1 0ms RS-Gateway.local [78.129.174.1] 2 0ms 87.117.211.45 3 1ms 593.core1.thn.as20860.net [62.233.127.173] 4 1ms linx1.ukcore.bt.net [195.66.224.10] 5 1ms core1-te0-8-0-2.faraday.ukcore.bt.net [109.159.254.180] 6 2ms acc2-10GigE-0-4-0-0.l-far.21cn-ipp.bt.net [109.159.249.128] 7 2ms 109.159.249.226 8 2ms 217.41.168.108 9 2ms 217.41.168.190 10 1ms 213.120.177.101 11 1ms 213.120.178.148 12 13ms host81-xxx-xxx-xxx.in-addr.btopenworld.com [81.xxx.xxx.xxx]
No increased latency at Faraday and no packet loss when the connection is normal
Connection has got even worse just hitting about 1meg on speedtest to various servers including the BT speedtester included another traceroute which shows a huge latency spike:
Tracing route to bbc.co.uk [212.58.253.67] over a maximum of 30 hops: 1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254] 2 13 ms 12 ms 13 ms host81-148-64-1.in-addr.btopenworld.com [81.148. 64.1] 3 13 ms 13 ms 13 ms 213.120.178.141 4 14 ms 13 ms 13 ms 213.120.177.98 5 14 ms 14 ms 13 ms 217.41.168.177 6 234 ms 271 ms 256 ms 217.41.168.107 7 14 ms 14 ms 14 ms acc1-10GigE-0-2-0-6.l-far.21cn-ipp.bt.net [109.1 59.249.101] 8 15 ms 15 ms 15 ms core2-te0-7-0-16.faraday.ukcore.bt.net [109.159. 249.9] 9 14 ms 14 ms 13 ms peer2-xe8-3-1.telehouse.ukcore.bt.net [213.121.1 93.111] 10 14 ms 14 ms 15 ms 194.74.65.42 11 * * * Request timed out. 12 16 ms 16 ms 19 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93] 13 16 ms 16 ms 15 ms 132.185.255.156 14 16 ms 16 ms 16 ms www-vip.cwwtf.bbc.co.uk [212.58.253.67] Trace complete.
Seems BT don't care anymore tried calling etc.
adsl: ADSL driver and PHY status Status: Showtime Retrain Reason: 0 Max: Upstream rate = 18426 Kbps, Downstream rate = 21752 Kbps Path: 0, Upstream rate = 1040 Kbps, Downstream rate = 18788 Kbps Link Power State: L0 Mode: ADSL2+ TPS-TC: ATM Mode Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 3.1 6.1 Attn(dB): 26.0 13.7 Pwr(dBm): 16.3 12.1 ADSL2 framing MSGc: 51 14 B: 223 130 M: 1 1 T: 3 1 R: 0 0 S: 0.3809 4.0000 L: 4704 262 D: 1 1 Counters SF: 449036 365662 SFErr: 39590 73 RS: 0 0 RSCorr: 0 0 RSUnCorr: 0 0 HEC: 37473 82 OCD: 1132 0 LCD: 0 0 Total Cells: 323664848 17930146 Data Cells: 8565742 2502749 Drop Cells: 45 Bit Errors: 0 4488 ES: 1321 39 SES: 659 0 UAS: 18 18 AS: 7313 INP: 0.00 0.00 PER: 16.28 20.00 delay: 0.09 1.00 OR: 28.00 8.00 Bitswap: 1398 54 Total time = 2 hours 2 min 20 sec FEC: 0 0 CRC: 590 73 ES: 321 39 SES: 59 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 Latest 15 minutes time = 2 min 20 sec FEC: 0 0 CRC: 1 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 0 0 CRC: 11 7 ES: 52 9 SES: 5 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 Latest 1 day time = 2 hours 2 min 20 sec FEC: 0 0 CRC: 590 73 ES: 321 39 SES: 59 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 Since Link time = 2 hours 1 min 53 sec FEC: 0 0 CRC: 590 73 ES: 321 39 SES: 59 0 UAS: 0 0 LOS: 0 0 LOF: 0 0
