Setting up SMTP Server
8BitBar
Member
I recently set up my domain at mydomain.com which came supplied with email addresses.
I have managed to set up these now, but the webmail client is terrible and I am attempting to use Mozilla Thunderbird to overcome this.
I however cannot find out what to set my SMTP server to, apparently I need to go through you guys to sort this?
I have encounted the same problem with Outlook 2007
The provider in question is webmail.provider.com
1 REPLY 1
Burkem5
Guru
Hi 8BitBar
I have edited your post to remove any account specific data or anything that could be user to identify your self.
As far as the mail relay goes you will need to contact us and tell the technical advisor that you have a 3rd party domain and would like to set it up so you can send through our server.
This can take 48 hours to go through but in the majority of cases you will be up and running on that call/chat
Hope this helps
Burkem5
