Synchronising email across office 365 and m/s outlook 2010
nessa8080
Member
We use [email protected] emails at work, and have just set up a shared [email protected] email that we all have access to.
My [email protected] is set up in Outlook 2010 and I've set up the [email protected] email in Outlook too as I also integrate it with Sage 50 for sending remittances and statements, which by default uses Outlook.
The problem I have is that anything that's sent from the [email protected] email address using M/S Outlook doesn't backfeed to the webmail version of Office 365.
Is there any way that I can set up the email so that everything that is sent and received using M/S Outlook feeds back automatically onto the webmail version of Office 365?
Thanks.
Ness
2 REPLIES 2
Burkem5
Guru
Hi there Nessa
If you are using BTconnect.com then you are using a POP email account, what this means is that when outlook syncs the email it only syncs the inbox and nothing else.  It takes a copy of the current inbox and downloads that into outlook.
To do what you need you would need an exchange email, this will sync everything inbox outbox and folders. Also when one person reads and email this will then appear as read in every other instance of outlook meaning that there will be no duplication of work from multiple members of staff.
To get exchange you will need to upgrade [email protected] to a 365 premium account which is chargeable (prices here) this will also give you a free or discounted domain name so rather than working from [email protected] you will be working from something like [email protected] with the old btconnect feeding all the emails to the old address into the new one.
This also comes with a host of other features and different levels of premium come with different features (features here)
Hope this helps
Burkem5
nessa8080
Member
Hi
Thanks for this, I'll pass it on to the boss!
