Tiny font for text with hyperlink
Joan
Member
I have followed the standard procedure for inserting a hyperlink into text, but when I do this the text font becomes tiny and the font changes. I have tried to increase the size and font of the text using the font tool but it doesn't work. What can I do?
12 REPLIES 12
Joan
Member
Orchie
Thanks for persisting on this one. I don't understand how to shift to html mode within Easy Sitewizard pro. Could you explain?
dave
Guru
You can change the hyperlink font / size / colour by doing the following:
Once you have applied the hyperlink, add a space to the end of the text, then highlight the text from the right including the space.
This will then allow you to edit the font properties, rather bringing up the link destination box.
You can then remove the space afterwards.
This method may not work in Firefox and may only work in Internet Explorer.
pete33
Member
Thanks Dave
I've had the same problem and just tried your solution and it works like a dream. This must be the easiest way to change the font size for a hyperlink. I'm glad I read your posting!!!
Regards,
Pete
