To Connect a handsfree phone to the same line as the versatility phone line
RCPS
Member
Is is possible to connect a handsfree phone to the same phone line as a bt versatility phone? I have bought a BT studio 4100 plus phone and have tried to connect it to the same line as the BT versatility with a double adapter, the new phone works but not the versatility. i need a handsfree and the versatility to work at the same time. Any ideas?????
2 REPLIES 2
Davel
Super User
No this will not work, the only way to do it would be to connect the hands free phone to a spare extension port.
klauzser
Power User
That is right. If you have a spare extension, you should be able to connect your hardsfree phone set. It should be plug and play.
