Transferring Domain to 123-Reg / ISP Tag
WillButler1
Member
Hi all,
I've just requested a transfer of domain from 123-reg.co.uk and it's currently pending... I need BT to change my ISP Tag to 123-Reg... Does anyone know how I can go about this? I'm trying to leave ringing BT as my last resort as it usually takes me around a day to get through to someone, only to get cut off 5 minutes later.
Please help!
Regards,
-Will
linnetts.co.uk
linnetts.com
1 ACCEPTED SOLUTION
Accepted Solutions
Fiona
Grand Guru
Hi
If you are with BT Business there is a help and support file to assist with transferring domains out of BT. To ask for the IPS Tag to be changed, please fill out the webform for DNS Transfer Out. In the webform for the .co.uk domains (and domains that are not .com) it asks you to enter the IPS tag you want the domain changed too. In the webform for .com domains it will ask for the new host details.
I hope this helps,
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
View solution in original post
6 REPLIES 6
WillButler1
Member
Sorry I mean IPS!!! Smiley Sad Not having a good day today...
WillButler1
Member
Would anyone care the hazzard a guess?! Please I'm really struggling to find a solution!
-Will
Fiona
Grand Guru
Hi
I hope this helps,
Kind Regards
Fiona
WillButler1
Member
Thanks for all your help Fiona. I had a good look around the site yesterday and found the 'Transfer Away Domain' page whilst browsing...
I've now sent a request so hope it all sorts itself out!
Thanks again...
Smiley Happy
Fiona
Grand Guru
Hi
Thanks for letting us know.
Kind Regards
Fiona
rwinslow
Member
Email me the domain name, [email protected] and I can check all things on our side.
Richard.
