Solved! Go to Solution.
Hi Steph,
Thanks very much for taking the time to get back to me on this. I seem to of sorted it out myself. I ran all the scans i could do and they found some spyware which i deleted. I then tried to update again and it did it no problem. So dam simple in the end. Feel a bit stupid now lol, ![]()
Hi Zoelee900,
In this instance it might be best if the technical team have a look at your account to see what is going on.
You can email them via the "Technical or general enquiry" online form, or call them on 0845 600 70 20, open 24/7.
Kind regards,
Steph
Hi Steph,
No worries, glad to hear you were able to fix this! ![]()
Steph
