Unstable Broadband
BML
Member
Every so often over the last few days I have lost my Broadband connection but when I check the avaiability site it shows no problems yet the village has been crawling with Open Reach working on what I assume is fibre optics.  Any suggestions on how I can obtain a genuine Broadband check would be helpfull.
3 REPLIES 3
BML
Member
I forgot to tick the Email box.
spank
Grand Guru
Hi there,
Check here https://www.samknows.com/broadband/broadband_checker
Once fibre show up here you should be able to order with BT.
markp
Grand Guru
Hi BML,
If you contact the helpdesk they can test the line for you to see what is going on with the line.
markp
