VoIP
chris_89
Member
Hi,
Im trying to set up a VoIP phone on the BT Versatility broadband module. apparently it used to just work when you plugged it in, but now it wont connect I was wondering if it could be somethin to do with the user domain settings and the proxy server.
when plugged in all the phone does is try to find the IP card and then says local IP card address is invalid.
any help would be greatly appreciated.
5 REPLIES 5
RichardQWS
Member
We are also having problems with our Voip and Versatility System. When it was first setup by the Bt enginner it seemed to work OK. Then after a period of time whenever we made a call it would only connect for 9 seconds then drop out. Since then we have tried to re-configure the system, but now will not connect at all.
Has anyone the correct setup details to get the Voip working. The phone are expensive and we would like to get the system working from our two remote offices.
Any help would be great
Richard
flogger
Member
I am also having the same issue. Hoping for some positive reply.
325consultancy
Member
Hi,
I have a PDF Broadband Module User Guide for the Versatility, happy to email you if this would help.
[email protected]
Best Regards,
Karen
Karen
Karen Rogers | Account Manager | 325Consultancy | Telecom & IT services
Email:
[email protected]
Phone:
+44 (0) 844 736 2675 ext 2676
Web:
www.325consultancy.com
Fax:
+44 (0) 844 736 2614
This communication together with any attachments transmitted with it ("this E-Mail") is intended only for the use of the addressee and may contain information which is privileged and confidential. If the reader of this E-Mail is not the intended recipient or the employee or agent responsible for delivering it to the intended recipient you are hereby notified that any use, dissemination, forwarding, printing or copying of this E-Mail is strictly prohibited. If you are not the intended recipient, be advised that you have received this email in error and that any use, dissemination, forwarding, printing, or copying of this email is strictly prohibited. Please then immediately delete, erase or otherwise destroy this E-Mail and any copies of it. If you have received this email in error please contact the sender.
Although we have taken steps to ensure that this e-mail and attachments are free from any virus, we advise that in keeping with good computing practice the recipient should ensure they are actually virus free.
Any opinions expressed in this E-Mail are those of the author and do not necessarily constitute the views of the Company. Nothing in this E-Mail shall bind the Company in any contract or obligation.
For the purposes of this E-Mail "the Company" means 325 Consultancy.
Videostar
Member
Hi Chris, did you get anywhere ?
I have the same problem - 3 VOIP phones worked perfectly until I packed them away two years ago and now they won't find the Versatility. I have the programming manual & software for the VOIP phones and the Versatility but it doesn't help. The phones (like yours) try to find the IP and fail but the broadband module software lists lots of IP addresses within the module but none are the address the phones are looking for. The module does, however, include the ID numbers of all three phones together with the extension numbers allocated to them. Nobody can (or will) tell me which IP address I need to change or even if it is the phone or the Versatility that requires the changes. I am absolutely desperate because I urgently need to get the extensions working again.
Dalesteyn
Member
Hello friend
Thanks for information you provide about VOIP services .
You give nice post.
