Hi Aaronleeds,
The blocked packets, will be the router blocking packets of incoming traffic not your outgoing traffic.
I hope this helps
Mark.
The firewall part of your router will block and silently drop malformed or incomplete packets received over a wi-fi connection - this is absolutely normal as you don't want corrupted packets (and hence data) in your connection. Because of the nature of radio-based network connections, mangled packets are a normal part of a wi-fi connection and the systems is designed to ignore these and request re-transmission if required - the retransmit requests don't make it into the router logs, so you'll not be aware of them.
Andy
