change page names
tylerandsons
Member
hi i am using easy site wizard and i want to change the names of some of my pages after i have created them is this possible because when i try it a message saying "Please enter correct file name" appears.. i want to change a page from kitchens.html to Fitted-Kitchens.html     my web site is www.tylerandsons.co.uk
3 REPLIES 3
duskjome
BT Partner
BT Partner
The program, in it's current form, does not accept capital letters or special character (the "-" for example.) So you could name the file fittedkitchens.html but not FittedKitchens.html or fitted-kitchens.html.
Hope this helps.
mournetraining
Member
Is this new? I have a website set up some time ago where I used a mixture of upper and lower case letters. I changed the properties of some pages in November and it worked fine but now I cannot make any changes. This is extremely frustrating since I have a lot of pages affected and will have to rename them, and find all incoming links throughout my site and externally. Any chance this change will be reversed?
Nguitar
BT Partner
BT Partner
It is something that was released in the latest version of Easy Site Wizard. Existing pages will not be affected. This will only effect pages created from here on out.
