eShop not opening correctly.
fixmyplasma
Member
My domain: www.fixmyplasma.co.uk points at my eshop:
http://www.fixmyplasma.co.uk/epages/Store3_Shop2248.sf
However, using firefox you get an error saying the server is causing the browser to loop, IE8 just brings up page not found ...
I know it's not me, I have had 20+ calls from customers who also can't get on?
Tried contacting BT, no-one knows who to contact, it's been 2 days now and it's getting me down not to mention costing me money.
Can anyone help?
10 REPLIES 10
dave
Guru
Did you get it working as it seems to be working ok for me.
If not you can contact BT about it by going to http://btbusiness.custhelp.com/app/contact#s=ImNhdD0xOTk1LDIwNDd8Zm9ybV9zdGF0ZT0wIg..
fixmyplasma
Member
It seems to work sporadically. works for some, not others. There is a DNS problem / server redirect problem somewhere.
Firefox this end says:
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
It's not working for me.
eShopTeam
Master User
Hello,
unfortunately I can not reproduce the error either.  It seems to work fine on every browser.
eShop Team
The eShop Team
dave
Guru
Sounds like you have maybe set up the domain to forward to itself. This will usually be sporadic.
You should contact BT to have the domain settings checked out
spank
Grand Guru
If it's any consellation I can see the problem.  The page did come up at first but the stylesheet was missing, when I refreshed it it went into this loop you where talking about.
But like Dave says it could be a configuration problem with the domain.
fixmyplasma
Member
I haven't done anything with the domain, BT Domain team are unhelpfull as they do not do the domains for eShop.
No-one else knows who to talk to?
BT sent me here
dave
Guru
Fill in the email BT form at the following link and it should be looked at quickly:
Go for Domains and Hosting > General Enquiry
Message Edited by dave on 25-09-2009 12:12 PM
orchie
Grand Master
Hi,
It looks like you have had the same issue as this post http://btb.lithium.com/btb/board/message?board.id=Webhosting&thread.id=2861 according to BT's reply this has been fixed so everything should be back to normal.
fixmyplasma
Member
Still not working for me. BT is "working" on it. The fault has been "escalated" to the eShop team?
So I'm told, I was also promised a phone call back with an update, but none so far....
I am beginning to give serious consideration to moving the whole site. 3 days at £*** per day in lost order alone.
Frustrated...
