editing easysitepro with easysite v.6?
phobic
Member
Hi all
I just spent a few days creating my website on easysitewizard pro. i just discovered from the forums that you need to use easysitewizard 6 to embed videos. is there anyway that i can import my site into easysite 6 to embed the videos, or do i need to start again?
thanks
dave
1 ACCEPTED SOLUTION
Accepted Solutions
duskjome
BT Partner
BT Partner
Unfortunately not, due to the nature of the two builders the content is incompatible between them, you would be left with either starting from scratch or linking the Easy Site Wizard Pro site to the Easy Site Wizard v.6 site to get to the link with the video. It may look a little different if the two templates do not match but it would be a good workaround.
View solution in original post
1 REPLY 1
duskjome
BT Partner
BT Partner
