If this is the wrong forum for this question, please let me know.
I am unable to delete or move mail folders within Outlook. For example, if I want to rename a folder; delete in permanently, or move one folder to be a subfolder to another, I get the error message 'mailbox is full'. It isn't...
This is a fairly recent problem. Does anyone have experience of this, or would more information be helpful.
John
Hi johnwadeovc,
This forum is fine for any email problems. Sounds like the local PST has become full rather than your hosted mailbox.
Are you using your own server?
If no then here's some info on PST size limits
Outlook 97-2002 Personal Folders File (PST)
Outlook 2003-2007 Personal Folders File (PST)
As your PST file approaches the limit or suggested maximum size (check the size via the Total size given in the Folder Size dialog), you can move old messages to a separate archive PST file — or delete them, of course.
Hi,
I think there's some problem with your PST file. You can use Outlook recovery tools to repair it. Below is a list of them:
http://www.datanumen.com/aor/compare.htm
Most of them provide a free demo so you can try first.
Steve
Try to delete a few mails including the ones in Deleted Files folder. Then try editing folders afterwards and see if it will work.
There could be three reasons for the condition your Outlook PST file has stuck in
Just like the cases mentioned above, the solutions would vary as well.
Reference: http://splitpstfiles.com
http://www.msoutlook.info/question/288
