security certificate cannot be verified
peteeden
Member
ever since you changed email system, we get this message every time we open outlook
settings are pop or smtp.outlook.com, ssl, ports in 995 out 587, authentication on
emails come through ok but how can we stop the message
1 ACCEPTED SOLUTION
Accepted Solutions
Stephenc
Master User
Hi Pete,
This is sometimes caused by office not being upto date, can you go into start - control panel - windows update and see if there are any updates available for Microsoft office?
Thanks,
Steve
View solution in original post
7 REPLIES 7
DaveA
BT Partner
BT Partner
Hi,
Do you have SSL enabled?
Dave
peteeden
Member
yes it is and port set at 995
DaveA
BT Partner
BT Partner
Hi,
What's the full message?  (Make sure to remove any sensitive info)
Dave
peteeden
Member
i'll have to let you know tomorrow if thats ok, as im away from there now
thank you
DaveA
BT Partner
BT Partner
Hi,
No problem.  I'm off home anyway in about 10 minutes.  🙂
Dave
Stephenc
Master User
Hi Pete,
Thanks,
Steve
peteeden
Member
Thank you very much Stephen, Top man.
there was 4 win 7 pcs, 2 had security certificate problem, after installing office sp3 the we get no security certifacte problem.
