trouble connecting to ftp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I was hoping someone may be able to help me,
I have been trying to connect using filezilla for some time, these are the settings i have been using:
host: ftp.thenumberfour.co.uk
username: thenumberfour.co.uk
password: ********* (my usual login password)
its set to passive
yet the only thing that happens is: connection established, waiting for welcome message, and then could not connect to server.
I do not normally have any problems using filezilla, does anyone have any advice?
John
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Check you don't have frontpage extensions enabled in your website centre (Site Builders > Frontpage manager)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have tested FTP access for you and it is working fine.
The details you are using are in the correct format so should be OK.
Regards,
Colin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
As Colin has verified that there is no fault with the FTP details, try rebooting your router and try again as it may just be a probem with your current IP address.
