usage
jimsim
Member
If I go over my broadband limit or the usage allowance, then you will charged for additional usage in units of 5GB, at £5 per 5GB.
So my question is this...If i've payed you for extra units and I only used one of them. Do the other units get carried forward on to the fallowing months usage. and if not is what you doing legal. because I can,t see any were were you state this fact.
1 REPLY 1
OldWolf
Guru
Hi,
They aren't talking about distinct units as such, although the wording is... odd.  Nice try though.
The initial amount and each 5 GB after is a threshold, so once you pass that threshold you get charged.  In the end it's up to you whether you decide to pass the next one.
And it'll be in your T&Cs.
Get Networx if you want to keep some form of track, although note that it won't count anything like mobiles, iPads, consoles, etc.
Hope that helps.
Cheers.
Dave A
