ADSL Business line times out under moderate load
JollyJamma
Member
Hi all
My cousins business ADSL line is very weak.
Under any load that puts a little bit of strain on the line, the latency/ping times goes sky high and then the line times out and the line ends up timing out.
email and texting is fine, light load doesn’t cause the line to drop out.
The line is a business connection of 12mbs down and 1 mbs up - so very slow by modern standards but even a moderate load such as FaceTiming or Zoom calls drop out, that should not happen.
I called BT and they pawned me off saying “you’re getting the stated line speed for your area blah blah there’s nothing wrong with the line go away”
I reiterated that it’s not the speed that’s an issue, the line hits the speed of 12 MBs and then drops out and the connection is unstable.
There might be corrosion on the line but it’s hard to tell.
I will replace the filter and use the test port this afternoon to see if that helps, I just need to document this and see if anyone has any suggestions.
fibre is coming to the area but it’s a very remote part of England and there’s no urgency by the ISPs to spend a lot of money on installing fibre for maybe 20 users, even if that’ll get rid of the ADSL issues.
if anyone has any ideas beyond replacing the filter and trying the test port, please feel free to say.
I will call the BT support line tonight if I can’t fix it today.
3 REPLIES 3
JollyJamma
Member
Hi all
just did some light browsing of LinkedIn whilst running a speedtest and got these timeouts.
Reply from 2a00:1450:4009:821::2004: time=114ms
Reply from 2a00:1450:4009:821::2004: time=123ms
Reply from 2a00:1450:4009:821::2004: time=147ms
Reply from 2a00:1450:4009:821::2004: time=99ms
Reply from 2a00:1450:4009:821::2004: time=83ms
Reply from 2a00:1450:4009:821::2004: time=77ms
Reply from 2a00:1450:4009:821::2004: time=137ms
Reply from 2a00:1450:4009:821::2004: time=32ms
Request timed out.
Reply from 2a00:1450:4009:821::2004: time=18ms
Reply from 2a00:1450:4009:821::2004: time=164ms
Reply from 2a00:1450:4009:821::2004: time=241ms
Reply from 2a00:1450:4009:821::2004: time=12ms
Reply from 2a00:1450:4009:821::2004: time=11ms
Reply from 2a00:1450:4009:821::2004: time=21ms
Reply from 2a00:1450:4009:821::2004: time=20ms
Reply from 2a00:1450:4009:821::2004: time=17ms
Reply from 2a00:1450:4009:821::2004: time=52ms
Reply from 2a00:1450:4009:821::2004: time=23ms
Reply from 2a00:1450:4009:821::2004: time=14ms
Reply from 2a00:1450:4009:821::2004: time=115ms
Reply from 2a00:1450:4009:821::2004: time=62ms
Reply from 2a00:1450:4009:821::2004: time=44ms
Reply from 2a00:1450:4009:821::2004: time=57ms
Reply from 2a00:1450:4009:821::2004: time=167ms
Reply from 2a00:1450:4009:821::2004: time=38ms
Request timed out.
Reply from 2a00:1450:4009:821::2004: time=259ms
Reply from 2a00:1450:4009:821::2004: time=238ms
Reply from 2a00:1450:4009:821::2004: time=346ms
Reply from 2a00:1450:4009:821::2004: time=269ms
Reply from 2a00:1450:4009:821::2004: time=184ms
Reply from 2a00:1450:4009:821::2004: time=277ms
Reply from 2a00:1450:4009:821::2004: time=349ms
Reply from 2a00:1450:4009:821::2004: time=188ms
Reply from 2a00:1450:4009:821::2004: time=217ms
Reply from 2a00:1450:4009:821::2004: time=130ms
Reply from 2a00:1450:4009:821::2004: time=208ms
Request timed out.
Reply from 2a00:1450:4009:821::2004: time=158ms
Request timed out.
Reply from 2a00:1450:4009:821::2004: time=33ms
Reply from 2a00:1450:4009:821::2004: time=54ms
Reply from 2a00:1450:4009:821::2004: time=60ms
Reply from 2a00:1450:4009:821::2004: time=74ms
Reply from 2a00:1450:4009:821::2004: time=59ms
These are the line stats
Product code:Business Smart Hub 2
Firmware version:v0.25.00.01066-BT
Firmware updated:Sun Apr 23 03:53:05 2023
Board version:R01
GUI version:1.77 06_06_2022
DSL uptime:0 days,00 Hours16 Mins11 Secs
Data rate:1.259 Mbps / 11.543 Mbps
Maximum data rate:1.255 Mbps / 11.728 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:6.7 / 9.0
Line attenuation:22.3 / 37.5
Signal attenuation:21.9 / 42.0
VPI/VCI:0/38
Modulation:G.992.5(ADSL2+)
Latency type:Fast
Upstream error control:Off
Downstream error control:Off
Data sent / received:42.8 MB Uploaded / 668.6 MB Downloaded
JollyJamma
Member
The above is with a replacement POP filter.
AdamC
Administrator
Administrator
Hi, if you can message me directly I can take the business details and we can arrange for one of BT Business technical specialists to contact you. Thank you, Adam
