Find out which BT Business Hub you've got.
Experiencing speed and connection problems with your broadband service? The quickest and easiest way to solve these issues is the controlled shutdown and switching back on of your equipment. This is called 'power cycling'.
If you've power cycled your router and it hasn't solved your connection issue, you may want to do a factory reset.
This returns your hub to its default settings, discarding any changes you've made to it. Factory resetting your router means that you'll lose any configured settings on your network.
Still having problems with your business broadband? Report a fault online.
