BT Business Hybrid connect - no EE signal whatsoever
JOC
Member
I had my BT Business broadband sorted by an engineer yesterday.  BT have supplied one of these Hybrid connect EE devices.  The broadband is quite happy to connect internally to the router, but nothing I can do is getting it to show a White mobile symbol, I've even tried attaching a couple of aerials which I've read about.  Absolutely nothing - just red flashing mobile connect symbols.  When I've searched for EE mobile coverage at this address it shows no indoor coverage.  Clearly I've been subscribed to a service that I can't take advantage of no matter how useful it might be.  Where do I stand and what should I do?
7 REPLIES 7
BethM
Administrator
Administrator
JOC
Member
Thanks BethM.   I did so, twenty minutes later the online help person came up with the fact that they couldn't help and to phone 0800 800156 - so that's going to have to wait until I've got some more time on my hands.  You would think that if this morning's engineer has agreed the EE signal is non-existent here that it would be simple matter to have resolved that online with someone.
BethM
Administrator
Administrator
Hi JOC
Can you please send over a private message with some account details so I can have a further look? Thanks
^BethM
Dv
Member
Hi Beth,
Im having a similar issue, but instead mine is that I haven’t yet purchased the product and I ain’t sure if I want the hybrid version yet.
would you recommend  talking with technical support team too?
BethM
Administrator
Administrator
Hi Dv
Yes, they can check the signal for you.
^BethM
Fishmon
Member
Had 3 of these devices and not one has ever worked for me total waste of time.
AlanM1
Administrator
Administrator
Hi there, thanks for coming back to us — having three devices and none of them working must be incredibly frustrating, and it’s certainly not the experience we want for you.
From what you’ve described, the Hybrid Connect won’t be able to work properly if there’s no usable EE signal at your address. The solid white mobile signal light will only appear when it can detect and connect to the local EE network — so if coverage is showing as no indoor EE signal, the unit simply won’t be able to do its job.
Here’s what you can do next:
🔍 1. Double‑check coverage
You can confirm EE coverage at your address using the official checker:
👉 https://coverage.ee.co.uk/coverage/ee
🧰 2. Troubleshoot the Hybrid Connect
If you'd like to go through all troubleshooting steps just in case, here’s the BT Business guide:
👉 https://business.bt.com/support/broadband/hybrid-connect/
📞 3. Speak with BT Business about your options
If there’s no EE signal at the address, you shouldn’t be left paying for a service you can’t benefit from. Get in touch with BT Business support so they can review your setup and advise on next steps:
👉 https://business.bt.com/support/contact/
They’ll be able to check your line, your contract, and whether Hybrid Connect should remain on the account given the lack of coverage.
