BT Business Smart Hub 3 DHCP
mwh65
Member
The new BT Business Smart Hub 3 we installed keeps enabling DHCP every time a firmware update is installed. This is interfering with our Windows Server 2019 DHCP settings. Yes turning the BT Smart Hub 3 DHCP off works but everyone has to restart their devices every time and of course come a new firmware update it gets turned back on.
I know this is happening as we had a port forwarding issue not so long back and a firmware update fixed it ...
https://business.forums.bt.com/t5/Broadband/BT-Business-Smart-Hub-3-Port-Forwarding/td-p/90029
and since then I have monitored the firmware which is currently on ...
Can this be looked at please.
1 REPLY 1
BethM
Administrator
Administrator
Hi mwh65
I have looked into this and can confirm this is a known bug that's being worked on. Unfortunately there is no ETA on the fix but I just wanted to let you know it is the pipeline to be fixed.
^BethM
