BT blocks block of static IPs
itmika
Member
Hi,
I cannot ping another BT business static IP and whole block of IPs.
Pinging 81.150.33.x (BT static IP for email server) with 32 bytes of data: Request timed out.
It works fine from a BT 4G Assure stick and it works from other networks.
Tracing route to 81.150.33.x
1 <1 ms <1 ms <1 ms 10.16.0.1
2 10 ms 10 ms 10 ms 81.148.64.1
3 10 ms 10 ms 11 ms 213.120.163.234
4 10 ms 10 ms 10 ms 213.120.163.252
5 10 ms 10 ms 11 ms 31.55.187.216
6 11 ms 10 ms 11 ms core2-hu0-8-0-5.southbank.ukcore.bt.net [195.99.127.186]
7 10 ms 11 ms 11 ms core6-hu0-0-0-26.faraday.ukcore.bt.net [195.99.127.70]
8 11 ms 11 ms 11 ms core2-hu0-17-0-0.colindale.ukcore.bt.net [195.99.127.51]
9 * * * Request timed out.
10 * * * Request timed out.
11 11 ms 11 ms 11 ms 217.32.25.93
12 * * * Request timed out.
13 * * * Request timed out.
(...) above is looping
How to get BT to fix this?
PS
I tried to call BT several times "static IP access is not BT responsibility"
Thank you,
Jac
7 REPLIES 7
itmika
Member
Hi,
I switch the connection to 4G Assure backup internet and another peculiar problem shows when connecting to the same router dynamic IP or static IP (both on the same router).
Dynamic IP -> 81.139.113.x
ping 81.139.113.x  -> Reply from 81.139.113.x: bytes=32 time=41ms TTL=247
Tracing route to 81.139.113.x
over a maximum of 30 hops:
2 1 ms 1 ms 1 ms 192.168.1.254
4 22 ms 26 ms 21 ms 10.124.74.68
5 29 ms 29 ms 25 ms 10.124.74.85
6 * * * Request timed out.
7 28 ms 33 ms 36 ms host213-123-18-10.in-addr.btopenworld.com [213.123.18.10]
8 29 ms 26 ms 30 ms host213-123-18-38.in-addr.btopenworld.com [213.123.18.38]
9 109 ms 60 ms 73 ms host213-123-18-50.in-addr.btopenworld.com [213.123.18.50]
10 30 ms 42 ms 30 ms 217.32.25.81
11 36 ms 39 ms 39 ms host81-139-113-x.in-addr.btopenworld.com [81.139.113.x]
Trace complete. <- All fine only on 4G Assure, fail on BT Broadband
Static IP -> 81.150.33.x
ping 81.150.33.x -> Request timed out.
C:\Users\admin>tracert 81.150.33.x
4 25 ms 23 ms 26 ms 10.124.74.68
5 29 ms 29 ms 28 ms 10.124.74.44
6 40 ms 39 ms 33 ms 10.124.74.45
7 60 ms 66 ms 54 ms 31.118.59.106
8 * * * Request timed out.
11 ^C (endless loop)
C:\Users\admin>
Seems the problem lies inside BT, isn't it?
Any suggestions?
What else do you think I can check?
Thank you BT, for sorting this problem out.
All IPs are accessible now.
itmika
Member
Hello again,
The problem is back:
C:\Users\admin>ping 81.139.181.27
Pinging 81.139.181.27 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 81.139.181.27:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\admin>tracert 81.139.181.27
Tracing route to host81-139-181-27.in-addr.btopenworld.com [81.139.181.27]
2 10 ms 10 ms 10 ms host81-134-160-1.in-addr.btopenworld.com [81.134.160.1]
3 11 ms 11 ms 11 ms 213.120.163.202
4 * 10 ms 10 ms 213.120.163.252
5 11 ms 11 ms 10 ms 31.55.187.196
6 10 ms 11 ms 11 ms 213.121.192.134
7 11 ms 11 ms 10 ms core6-hu0-7-0-26.faraday.ukcore.bt.net [195.99.127.52]
8 11 ms 11 ms 12 ms core2-hu0-16-0-4.colindale.ukcore.bt.net [109.159.252.139]
9 11 ms 11 ms 11 ms host213-121-192-43.ukcore.bt.net [213.121.192.43]
11 11 ms 11 ms 10 ms 217.32.25.93     stops on the same device IP
 ^C
Please do not hesitate to give me any suggestions.
itmika
Member
To help with the timing of the issue started.
itmika
Member
At 4:36 am, 5/2/2023, IP started to work.
Thank you
itmika
Member
Hi,
It does not work again since:
19 February 2023, 4:48 am
Is there anyone who can give some light on this problem?
From today (28/02/2023), employees are affected as well!
Please advice.
Be aware that research-heavy jobs usually look for historians with free games.
