Bridge Mode Questions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
I am due to fit a FortiGate firewall at a site that has BT Business broadband in the form of FTTC. It appears to be VDSL as the speed is about 70mbps and the BT wholesale finder shows that as the VDSL speed.
We will be putting their BT Business Hub 5 into bridge mode and then plugging the WAN port of the FortiGate into the Hub.
With it being VDSL, will this just work on DHCP? Or do I have to setup PPPoE and use Vlan 101 on the FortiGate?
When logging into their BT Busines Hub 5, I can see authentication settings with a XXXXXXX@HGXX.btclick.com username in the connection information. However, im not able to see the password.
Please can someone advise what I will need to complete this setup?
I also have an Openreach modem that I can use too if that will make life easier.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi AvidPontoon
In regards to the authentication details needed, this is specific to the Broadband connection and therefore will need to be confirmed with the technical team. If you still require these, please message me privately so I can look into this for you.
Beth
^BethM
