Does living next to an electrified railway cause WiFi outages?
BalloonCow
Member
Some friends of mine recently moved into their new house (in Belgium.) It is located on a small hill, next to a double-track, electrified railway. Some 2-6 trains pass by every hour, depending on the time of the day.
The ground level of the house is roughly on the same height as the power lines feeding the trains. I guess the horizontal distance between the router and the closest power line is some 40 meters. There are no obstacles in the way, except for an outside window and some small bushes.
My friends experience lots (anywhere between 5 and 20) of 'WiFi outages' per hour: periods of 10-60 seconds that not a single device in the house (cellphones, tablets, laptops,...) can make a connection to the wireless router. Horrible to watch series online, apparently.
The router itself is in the upper class of routers: it's a Linksys WRT of some 2 years old that delivers a clear and strong 2.4 and 5 Ghz Wifi-bubble around the house. Works perfect 80%-90% of the time.
We were wondering if the trains or, more likely, mcdvoice their power lines cause these WiFi outages. An engineer I know (working in a completely different field) told me something about 'power inversion' on the lines happening several times per hour, almost always right before a train passes. I am not sure I understood him correctly. 🙂
This issue lingers around in my head for a couple of weeks now, so I come to the esteemed panel here for answers:
  • Is there indeed some sort of 'power inversion' happening on electrified railways (in Belgium?)
  • Is it possible that the effects of this inversion reach into my friend's house and affect their router?
  • Can they shield their router in any way to prevent the Wifi-outages?
  • Is 2.4 Ghz more or less affected than 5 Ghz? (Should all their devices connect to one instead of the other?)
Thanks a lot for helping solve this riddle !
2 REPLIES 2
spank
Grand Guru
A riddle indeed 🙂
I suppose it's entirely possible and by the sounds of it you're fairly convinced that the issue is with the train or lines. So how do you go about proving it is the real question.
I am no electrical engineer but I had a quick search and found this site which seems pretty rich in information and may help you understand better than I ever could. It does mention:
Power sources — electrical railroad tracks or power lines that are in close proximity can be causing WiFi interference. If you can try not to position your Wi-Fi router near power lines in the wall or close to the breaker box.
https://www.netspotapp.com/wifi-interference.html
finleyjamessz
Member
Problem with 192.168.100.1 address
Everytime I type in the 192.168.100.1 address, I receive a message "Internet Explorer Cannot Display
Webpage". I have tried this several times and it doesn't connect me to the website.
HELP!
