Hello,
I operate a DVR system on my network, all setup and I can locally access it. But when i go to http://192.168.1.254 (routers settings - I use a Business Hub 3) it says that other devices are connected but my DVR isn’t? I wish to port forward but I can’t without the DVR appearing on the router.
But as I can connect to it on a local address (192.168.1.100) I know its connected to my router/network.
Any assistance would be great!
Thanks!
Have you tried splitting the wifi into two frequencies? Some devices will only work on 2.4Ghz and only if the wifi is split. Can you connect the DVR to the Hub via ethernet - just temporarily?
