Hybrid-connect in bridge mode??
scottydj2
Member
Hi,
Can anyone give a definitive answer on whether the hybrid-connect (EE dial-up) mode will work when the smart hub is in bridge mode (business version)?
Tech support seems to think it should. Practice with ethernet cable between the two says it doesn't.
From a technical standpoint, it shouldn't matter about the mode. If the ADSL/Fiber goes down, switch to 4G.
Thanks,
Scott
1 REPLY 1
AdamC
Administrator
Administrator
Hi,
EDIT: Hybrid Connect will not work if the router is in bridge mode. I'm sorry you have been misadvised by the Tech team, I will have this fed back and corrected.
