I'm getting the following error when attempting to receive email. Unable to connect to server. (Account 'something', POP3 Server 'yourdomain.com', Error number 0x800ccc0e)
who knows how to stop it??
Solved! Go to Solution.
. Shutdown Outlook completely, including any runaway outlook.exe processes in the task manager. Open Mail in the Control Panel and before you delete your profile completely, write down the server settings! There’s no need to worry about backing up your mail as it’s stored on the Exchange server. (Essentially, you’re deleting that outlook.ost when you drop your mail profile.) Now, start Outlook and it will create a new profile, where you’ll configure the server with the information you wrote down previously.
Outlook will start normally again.
See more : https://groups.google.com/forum/?hl=en#!topic/outlook-email-connection-error/KjJpyiSHe4A
It is very common to receive the error message 0x800CCC0E when configuring an email account in Outlook and trying to send an e-mail, the reason why you get the error is because Outlook is not authenticating your account on the server while sending it, so the outgoing mail server rejects the message.
Regards,
J Wick
