I just upgraded my broadband to full fibre and I’ve been given a hub and a Yealink DECT IP Phone (W73P).
I have been provided with my username and password by BT so I have swapped out the provided hub with my 7590 and everything is fine with it. However, does anybody know if the IP Phone can be used with the 7590? If it can, does anybody know what I need to do? If it cannot, can I just use a normal DECT phone connected to the 7590?
Hi chiss
We don't support 3rd party equipment but I see no reason your 7590 wouldn't work with the handset as long as you configure your router correctly. In terms of using your own DECT phone, no you have to use our provided handsets with the service.
