Cisco ATA login details
Dr_Clint
Member
Does anyone know whether BT change/set the username and password for the ATA adapters when they commission them remotely?
We have a unit which was bought on eBay and setup/commissioned by BT but won't accept the default login details.
If I did change them, I certainly can't remember what they are as I forgot to write them down!
2 REPLIES 2
Dr_Clint
Member
Turns out BT do in fact change the login details - even though they tell you otherwise.
Did a factory reset on the ATA, changed the default password for the admin account (all while no dial tone on the connected phone).
Once the dial tone returned, the user name and password no longer worked.
I want to log in to the adapter to utilise a second VoIP service on the second line, but this is preventing me from doing so.
thefurmanuk
Power User
Did BT give you the details to enter into the Cisco ATA?  I just signed up last week and got my ATA 192 from Ebay too.
