How to change the time and date on a Norstar system
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
We no longer support this system.
Norstar Compact / Modular system
To change your system time and date:
Place the programming overlay on any M7310, M7310N, and M7324, M7324N or T7316 telephone.
- To enter programming press Feature**23646 the display shows: Password.
- Enter your password (the default is 23646) the display shows:
1. Sys speed dial.
To alter the time (go to step 3) to alter the date (go to step 11). - Select Next until display reads 3. Time & Date.
- Select Show, the display shows Time xx:xx.
- Select Change, the display shows Hour: xx.
- Select Change, the display shows Hour.
- Enter Hour, use the 24hr clock format. e.g. 14=2pm Hour: 14
- Select Next, the display shows Minutes: xx.
- Select Change, the display shows Minutes.
- Enter Minutes, use 2 digits eg: 08 Minutes: 08 The system time is now set, select Rls to exit programming or
- Select Next, until display reads Date xx xx.
- Select Change, the display shows Year: xx.
- Select Change, the display shows Year.
- Enter Year, use last 2 digits of year eg: 10, Year: 10.
- Select Next, the display shows Month: xx.
- Select Change, the display shows Month.
- Enter Month, use 2 digit format eg: 04 for April, Month: 04.
- Select Next, the display shows Day: xx.
- Select Change, the display shows Day.
- Enter Day of Month, use 2 digits i.e. 01 to 31.e.g 09 Day: 09.
- Select Rls to exit programming.
Norstar Compact Plus and Modular Plus system
To change the time and date, from any M7310(N), M7324(N) or T7316(e) telephone, leave the handset down:
- Press Feature **8463.
- Enter the Admin Password (the default password is 23646).
- Press Change.
- Enter the Hour.
- Press Next.
- Press Change.
- Enter Minutes.
Go to step 8 to alter the Date or step 14 to Exit programming. - Press Next, the display shows Year.
- Press Change to change the year.
- Press Next, the display shows Month.
- Press Change to change the month.
- Press Next, the display shows Day.
- Press Change to change the day.
- Press Rls key to exit programming.
To change the time by one hour:
Norstar Compact & Modular Plus systems allow you to forward the time by one hour.
Norstar offers two features that let you adjust the time quickly for changes in British Standard Time.
Moving one hour forward with ** FWD:
- Press Feature **393 (FWD). The display shows Forward by 1Hr?
- Press Yes. The display briefly shows Time Changed.
Your Norstar should now be showing the correct time.
Moving one hour backward with ** BACK:
- Press Feature **2225(BACK).The display shows Backward by 1Hr?
0
Kudos
0 REPLIES 0
