BT Router Pin
pstevenson1
Member
Hi, I am trying to connect a raspberry pi program (Astroberry) to my wifi. It is asking for a 4 to 8 digit router pin , but my router does not show a pin no ?. What is it and where can i find it ?
1 REPLY 1
kelper
Guru
Which router is it?
You should be able to use the wifi password, not PIN, according to this
https://www.astroberry.io/docs/index.php?title=Astroberry_Server
The BTB Smart Hub  does not offer a PIN.
