Any guidance would be appreciated?
dt1mm5
Member
Hello,
www.hrut.co.uk
Below is a query from my website developer, could anyone be kind enough to help?
Below in read is a previously relevent thread.
Thank you
Derek
Hello Mr. Timms:
We uploaded the Website Pages on  FTP and according to last email, we have  enabled the Service of ASP.NET from the Server Control panel.
While we enabled the Service of ASP.NET, system gives this message :
"This Service is currently Queued...Activation may take up to 1 business day to be completed."
One more thing, related to Database, we use Microsoft SQL Server 2005  Database as back-end. And we didn't find the MS SQL Server database in Hosting Control panel.
We found only MySQL database, that is no longer used by us.  So kindly mail to BT hosting about avability of MS SQL Server 2005 Database with remote connection. So we  can easily upload our Local Database schema to Server Database. Regards,
Amit Barot
PREVIOUS POST
Hello,
www.hrut.co.uk
Thank you
Derek
Hello Mr. Timms:
We are able to access the server.
But as we have developed the project in ASP.NET as Front-End and MS SQL Server Database as Back-end. For that, generally "WINDOWS BASED SERVER" is required.  That can have MSSQL Database support as well ASP.NET Support. The BT server seems to be on LINUX. In that, we are not able access the MS SQL Database, it supports only MySQL Database.
Kindly forward this mail to the concerned person in BT and let us know of any altenrative.
Regards, Amit Barot 840 121 6296
Hi dt1mm5,
In order to activate Asp.net please upload the website files to your webspace first.
Once done if you log into the BT Website Centre via your account.
Under Site Builders, click the "windows services" option on the left had side, from here you can then activate ASP.net.
Kind regards,
Ian - F -
4 REPLIES 4
darkulap
Member
I just hope it would be easy for BT do have this type of database available for you. Good luck.
Stephenc
Master User
Hi dtimm5,
I believe we run a Linux / windows hybrid server.
However if you require an MS database as used by Microsoft Access, we can set this up, however we need to raise a requets to the guys who manage the servers, if this is required contact 0845 600 7020 and we should be able to arrange this.
Thanks,
Steve
dt1mm5
Member
Thank you for your comments.
Could you give me an email address to make the request I have been struggling to get an answer from the number below.
Thanks, Derek
Stephenc
Master User
Hi Derek,
Yeah the tech desk don't deal with this in depth, but should have been able to transfer you to the correct department.
You can send us an email by going to http://www.dnsforms.co.uk then clicking hosting general enquiry and fill out the form there.
Thanks,
Steve
