Hi,
I'm having trouble configuring port forwarding on this router, is there a more advanced configuration page that I'm missing?
Thanks,
Rob.
Hi
There are details of setting up port forwarding on our help and support site, if your router homepage doesn't look the same as this step by step you may have the new firmware on the router. With the new firmware you would need to:
When you click on save it will ask for your password, this is your router password and not your connection password, if you cannot remember this click 'forgot password' and then 'forgot password again'. You can then go through the steps to reset your router password.
I hope this helps
Kind Regards
Fiona
BT Business Forum Moderator
If I follow the instructions to reset the password to enter the control panel, will this also delete the connection username and password?
